compression test
PynkEye
Ok, tomorrow ill be checking out my compression.
Need some pointers.
Heat up the car, wait 10 min to cool down, then take out the EFI fuse so no gaz goes there.
Do I take out all the spark plugs ??? or one at a time.
Do I need to unplug the coil pack ??? and how.
Any pointers on how to do the job right or links would be great.
Thanks
Pull all the plugs
either hold the throttle down when cranking or wire it open
If you don't unplg the coils make sure none of the leads are near you while cranking
Remove all the plugs
have a booster battery handy in case the voltage drops
