I have a no fuel no spark condition. I have new coil packs, new ignitor, crank and cam sensors are within range, timing is dead on, new fuel pump, blitz ecu getting power, no codes, new injectors, and fuel to the rail.... did I miss any thing!!!!???
I was wondering if the timing can be 180 degrees off? There is a big discussion on it on the other forum in the 2jz section but it was back and forth. I can see how it could be because the intake cam has the two cam sensor marks on them sweeping past the two senors 180 degrees opposite of each other. Maybe I'm wrong. I just dont know what the problem is with the car.
I remember someone saying that you you need fuel in order to get spark(or the opposite way around) is this correct? Should I be concentrating on the fuel problem before the spark issue or is there a problem that can cause both not to work? Thanks
