I first thought that I had a problem with my alternator but I am now considering that there may be a big vacuum leak. At idle, the engine runs poorly and idles anywhere from 500rpms up to 1500rpms. When I drive it, it sometimes stalls out when I put it in neutral. The rpms will fall all the way down to 0 and shut off completely. Most of the time when I do this, it falls to around 400-500rpms and then shutters a little bit and comes back up to around 800. Anyways, I was wondering where some common places would be for vacuum leaks on the 7m so I could spray around with carb cleaner. Thanks
