Collets / Retainers
Kai
That Limey Bastard
Why do these things have to hold up the whole job? I swear, in an hour, i've done 4 valves, cleaned, ground in and ready to replace but can i fit the f*cking things back in? NO.
I'm still on exhaust valve #1. I can fit ONE collet in, but the spring bends slightly to the side under the spring compressor, so you can't get the other one in.
I'm trying to wedge them into the ring but no luck - one goes, the other...AAAARGH
HOW? JUST....HOW!?
**edit**
Can i use vaseline to secure them to the stem? Or is that a no-no?
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Yes, I use grease to stick 'em to the valve stem. Then compress the spring a little too far, so they go onto the stem where they'll end up, and release the pressure on the spring gently. Works pretty well, I only had one collet launch itself into obscurity somewhere in the garage.
