When I start my car and its still cold the engine seems to have very low power. In park ill tap the throttle about 1/4 down and the RPMs will fall and then rise like normal, like it mis-fires. But when it warms up the problem will go away and it runs like a champ. It doesnt blow any smoke and as far as I can tell is in tip-top shape.
Some info about my setup. Its basically a 7m-gte short block with 7m-ge manifolds, sensors, electronics, manifolds, etc. It was a non-turbo then I bought a 7m-gte which came with the block, internals, head etc...(short block)
Any clues? Im thinking its retarding the timing for some reason... I know you shouldnt run the engine hard when its cold and im not doing that at all. But this doesnt seem right...
