cold start injector
lagged
1991 1JZ
new rochelle
your car is running rich? have you checked all your ic pipes? have you tested your o2 sensor? checked error codes? checked timing?
huntin5L
Niles, IL
Well the results of my compression check are as follows.
#1 150
#2 150
#3 155
#4 155
#5 153
#6 150
I think that is in range, so i look good there.
bigal0043
813
Plattsburgh,NY
www.mk3supra.net
the csi can be taken off without having to take of the manifold... just follow the directions in the tsrm to removing it... basically was unbolt the fuel line then unbolt the two bolts on the injector thats connected to the manifold... then unplug connector mine was all gunked up just clean it and see if that makes a diff
huntin5L
Niles, IL
I was on the online tsrm to find out how to change the injectors and there is no information on it. Just testing the injectors. Anyone have a good writeup on how to change them.
huntin5L said:
new/used?
