Cold Air Intake
supradupra1990
11
Union City
Was bored and wanted to show you guys...Got the intake off ebay for less than $40 thats with the shipping and tax included..came with a cheapo ebay filter two pipes that i had to cut to make fit on my car (intake was made to fit a honda prelude) couplers and those metal strap things...all in all its a pretty cheap and great mod if you got NA and you can deffinitly hear the motor suck up air at WOT sounds awesom
http://www.cardomain.com/ride/2239379
supra90turbo
shaeff is FTMFW!
32
MA, 01440
NO... Do you know how much a filter ruins airflow?!
It causes all sorts of turbulence, and so on... I don't want to get into that, though... Since you apparently have no idea...
jimi87-t
1,126
4
Colorado Springs
You don't need a filter when your motor is hydro locked.
No offence to you supradupra1990, I don't think you will have a problem with it. (just don't drive through large puddles, or in heavy down poors)
tubbie
Yes, powerful Jedi....
Apr 4, 2005
821
Hoschton, GA
Well, at least he got it for a great deal. Looks great... :bigthumb:
Last week somone was selling a "cold air intake" for the NA supras on ebay (looked exactly like his) and it sold for $200 +.
tubbie
Apr 4, 2005
821
Hoschton, GA
supradan22 said:
I may have just figured out my next ebay scheme lol
:rofl: go for it.... There's lots of NA suckers out there to be had. :rofl:
Actually the ones from the 88-92 civic works even better....
"Also the Apexi I intake is know to have the least amount of turbulence."
- Who tested it or is this another one of the I heard he heard internet forums rumors....?
Suprastic
727
Manitoba
I think it was a link on drjonez website that had results of the Apex, K&N, Blitz, and HKS. I remember seeing a website with all the filters tested and proven for their truness in quality. The Apexi was #1. I'll try to find the link
tubbie
Apr 4, 2005
821
Hoschton, GA
I have seen that test. The Apexi just sucked in less dirt then all the other one, don't remember it saying less turbulance......
N
NDBoost
Guest
I was actually thinking of doing this. but not going all the way to the ground. I wanted to put it just under the head light and make a plexi box in the normal area to help keep air out.
Suprastic
727
Manitoba
The Apexi was designed to reduce turbulence. Weather it works or not, I don't care. I'm not racing around on a formula1 circuit, and I bet you aren't either. Sometimes I think that people on here think that they are F1 drivers and are soo concerned about little things like a bit of turbulence or sheading aboput 200lbs of a car that weighs enough anyways. Is there a noticeable difference, not enough that it is worth doing it. In short, I wouldn't risk putting no filter on my car and risk damage in the long run because I think that an aftermarket filter has too much turbulence. What would the difference be in a 1/4 mile, maybe 0.0001 sec. with the filter.
supradupra1990
11
Union City
I do have a air filter on the end of the pipe i said it was a cheap ebay filter (came with intake) i dont have the intake all the way to the ground its barely where my right side fog light used to be..having water sucked up is a bad thing even though its usually sunny here in the bay area any way im planning on getting a outerwears prefilter goes around the filter and keeps water and your filter from getting dirty quik heres a link to the ebay autcion i got the intake from
http://cgi.ebay.com/ebaymotors/ws/e...&item=8025779403&rd=1&sspagename=STRK:MEWN:IT
AGlobalThreat
Acceleration
Apr 4, 2005
991
Santa Clarita
Don't mean to be rude, but this is old news. There's a couple NA people who have used this kit already and posted about it (On SF tho).
I have mine routed into the exact same spot, been like that as long as I can remember. It works pretty good.
And as far as u guys comparing the filters, it doesn't make NEARLY as big of a difference on the NA since it isn't sucking in as much air. Paying over $100 for an apexi filter that will give u maybe 1 hp over a cheap K&N cone, or even just a generic one.
When you're turbo, u need a good cone filter, when ur NA, u need a cone filter.
