boostin89 said:im not talking about a drop in filter, the full CAI can be an automatic smog fail in many areas, unless it has carb CERT. and a DIY cold air wont have CARB CERT.
Hum, that's really helpful. I was thinking about doing something like that, but I didn't want to blow money on stuff that hadn't been tested, but I've heard similar, from a couple people, so I think it's worth a try.Fuzz420 said:Theres is no cold air kit, they dont even make a pipe to replace the accordian hose :nono:, its a shame really. As For the k&n FIPK kit its a little pricey but its worth it.To verify, yes the adapters for the gte and ge are different, i know because i got a gte adapter by mistake. The fipk kit is carb legal and you even recieve a carb excempt sticker upon purchase.As for a cold air kit you can use the fipk front half and then you can do the "civic intake mod" off ebay.You get the 96 kit and use the piping and and hacksaw to shorten the bend and go from there. For more information search "civic inake mod" or something of the like and you should find a quick answer
RedEleven87 said:So if I have the Honda Civic intake mod, it won't be smog legal?
1TuffSupra said:its more like a sound thing IJ. The stock piping and filter may flow quite well, but it definitely will not give you that deep sound that a nicely made intake will produce.
1TuffSupra said:Well there is always a way to work around the man. You wouldnt be able to get an el cheapo ebay intake, but you could get a nicer intake that does have carb exemption status and use it on your car. Or just cheap out and get an ebay unit and swap your stock components back in when you need to get inspected. It shouldnt take you any longer than 10-15 min to do so.
