This is kind of a continuation of my other thread "life expectancy of coil packs". i felt it might need a new one.
Basically i did the coil pack check according to TSRM, my results
:I did the resistance check which resulted in .5-.6OHMS - good
I did continuity test and all tested infinity/0 - good
Check coil pack 1 voltage: 11.7-11.8V - good
Check coil pack 2 voltage : ~11.8 - good
Check coil pack 3 voltage: 0 - not so good???? whats going on??
How could that be? Maybe a loose wire i understand but is it possible my car could be running and with power with a coil down?? I'm lost. Guidance needed.
FYI my car bucks through the RPM range (most noticeably when cold), my narrow band A/F rapidly goes from Stoich/rich to lean when the lack of power happens. (yes narrow bands arn't reliable but it keeps in sync with the acceleration flaws)
Is it possible i could be getting very low voltage to the coil thus not enough spark as needed but enough to combust??
