So I guess I've got too much time to tinker some times. Reading through the manual on the coil packs it says to disconnect each plug to the coil pack and compare the resistance. It states that it should be between 140-180 ohms.
So I set the ohm meter to 200 and I get 1.1 on each coil pack. To me that means 110. Which would be out of specs, I tested another spare set I had and it measures 1.0 or 100. Am I completely off here or does this not really matter that much. The car runs fine, I was just tinkering.
How many people have actually tried this and what reading did you get? Thanks.
