coil pack relocation done!
supraturbotimmy
61
uk
after seeing a thread on here a lil while ago i gave it a go and am very pleased with the results :)
wasn't as bad to do as i thought.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Looks good. I hope you never pop the coolant hose at the back of the head that's under it ;)
supraturbotimmy
61
uk
thats a brand new genuine one under that coil pack its only a year old with a t bolt clamp holding it on :) i should be ok for a while lol
the point is to clean up the area a bit and with na cam covers on it should neaten it up a bit, plus it may be nothing but it might make the coil packs a bit cooler not sitting on top of the engine at the front, time will tell..
gofastgeorge
944
Texas
Nice !
I agree, NA cam covers would look better now.
By the way, if you want to clean things up a bit more,
pull those 2 tubes that are pressed into your throttle body, that you have hose looped on.
Find someone to make a couple of aluminum press-in plugs to go in their place.
supraturbotimmy
61
uk
your right i used the stock leads and just swapped the order round, i do actually think they fit better then in the stock location lol
tsuper92
supra addict
Apr 7, 2005
1,376
mass
this isn't as easy on a lhd supra.we have a bellcrank set-up for the throttle linkage.
the is300 cop set-up would look even cleaner
supraturbotimmy
61
uk
i agree cop would look great and with the arz billit cam covers even better but this mod cost me bugger all and its a start of things to come :)
tsuper92
supra addict
Apr 7, 2005
1,376
mass
i hear you there.i'd do the same,but the stupid throttle linkage.i should just try and make a bracket and modify the throttle linkage,some how.
i've been on the look out for some is300 coil's too.
Dec 3, 2003
6,653
Canada
Gonna say the same thing, Also, the coil packs would be hotter at rear of engine since it's closer to the exhaust. Now to get the ARZ covers. ;)
Duane
