coil pack ground wire?
Status
Not open for further replies.
forcefedsupra
aka, Turd Furguson
Jul 19, 2005
463
Jacksonville, FL
I have a very rough idle. I am doing research to see what it could be and everyone mentions a ground wire from the coil pack to the head. My car never had this. I found one pic but it didn't show exactly where the wire hooked up. Any help would be greatly appreciated since I can't look at where the original was.
jdub
Feb 10, 2006
10,730
Valley of the Sun
I modified mine...14 guage and made it longer so I could ground it on the manifold with the rest of the grounding wires.
supra90turbo
shaeff is FTMFW!
MA, 01440
not the worst idea ever. i ran without one for a long time. actually, because i never had one, and it was broken off clean inside the harness, so i didn't know i was supposed to have one.
ran fine.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Not having a ground for high voltage electrics (like coils) is not a good thing. You might get away with it, but sooner or later the electrics grimlin is gonna get ya ;)
outofstep
Senior Member
fwb
I ran an extra ground wire off of the coil pack as well as replacing the original one with thicker gauge wire.
jdub
Feb 10, 2006
10,730
Valley of the Sun
It attaches on the coil mounting plate on the drivers side, just forward of the right coil. There's a small hole for the screw.
suprarich
Guest
Nov 9, 2005
2,187
ohio
It is just a field ground for the metal plate that holds the coils and has nothing to do with the coils. I have run with out it for 4 years on one car and 5 years on another.
Status
