Don't worry, I searched on here but I really didn't find the info that I needed. Anyways, I have 86.5 turbo. My car was running and starting fine until today. I went for about an hours drive to a store today. My car was about 80-90 celcius which is normal for me. About five minutes to go before I arrived, my temp spiked to between 95 and 115 celcius! I got to the store and was there about half an hour. Came out car fired up, temp was about 85 celcius. I am rolling out of the parking lot and the temp is still spiking. Then my car just dies, but accessories are still good and battery voltage is still above 12.5. It wouldn't start at all, just kept cranking over.
So I knew my thermostat was pooched, but I couldn't take it out because of lack of tools. I sat for about 15 minutes and let the car cool which seemed to do the trick, cause it fired back up. So I was on my way home. About ten minutes from leaving the parking lot the temp spikes again this time ranging between 90 and 110 celcius, mostly at 100 since it was highway. I ended up making it all the way home. Took that thermostat out and ran the car some more. Everything was fine, starting and running.
Here is fun part. I go inside for about half an hour, come out and go to start, nothing..... just keeps cranking over. The temp was about 80 celcius. So I let it sit some more and tried it again when the temp was about 60 and it started. Since then it has been intermitant between starting and not starting.
I have checked out my igniter box and found that coil pack 1 and 3 are getting 8.90 to 9.10 volts and coil pack 2 is getting full voltage (about 12.3). I am just wanting to make sure that my igniter is messed up and not something else, wiring coming into the box is fine.
An input is much appreciated. Thanks.
