Codes and Boost Guage
tropical 87t
68
Lake City, FL
Need a little help. We have three code on the Super Monitor
ECT 0
CC -
ABS 0
ENK ok
The last one is easy. What does the 0 code mean?
Lastly, the boost guage on the dash is pinned at the top whether the engine is running or just the key is on.
Any ideas?
Thanks
mrsoup
19
LONDON
ECT 0
CC -
ABS 0
ENK ok
Any ideas?
Thanks
is your turbo pressure sensor pluged in ? it sits on the lh side of the engine bay has three wires and a pressure feed going to it
tropical 87t
68
Lake City, FL
On the codes, that's what I thought but just wanted to be sure
We found the plug to the boost pressure monitor was unplugged. The guage now reads -4 at idle but does not move under load
mrsoup
19
LONDON
ok well youre half way there, check the plastic pipe that feeds the sensor with a pressure vacume feed from the inlet manifold
tropical 87t
68
Lake City, FL
Ok, we connected the vaccum line from the intake manifold to the t-connector right behind it on the plastic pipe.
That plastic pipe goes over to the pressure sensor that includes a branch-off to the cruise control unit in between right?
Now the boost gauge reads "0" when idling but when driving we get no movement of the boost gauge above "0" and we hear no turbo whine at all. Actually, the engine seems more sluggish where it would usually boost.
Thanks for the help.
N
NDBoost
Guest
boost leak,
check your intercooler hoses and vacuum lines :(
mrsoup
19
LONDON
ok next job is pull of the big inlet hose to the turbo and see if you can spin the turbo . it should spin nice and smooth .. if it does only other thing it could be is your waste gate jammed , allthough you should see some boost
