Code 64, power antenna problems..
Doward
4,245
Alachua, FL
Code 64 - severed or defective lock-up solenoid ('88T, a340e)
To replace the lockup solenoid, do I have to drop the transmission, or can it be replaced while still in the car?
Part number?
Now, the power antenna - I can hear the motor working fine, but the mast doesn't move. Anyone have a part number, for a replacement mast?
clifftrail
128
Abq
A mast won't do you any good if the nylon cord broke. If you mast is not broken, 99.9% chance you'll need a new motor or a used one with a good nylon cord. Only way to be sure is pull the mast off a see. If you want a new one, order from Jay Mark's Toyota, used one that works, good luck hard to find, but the good news is, many Toyota antenna's are universal throughout the line-up so if you have a salvage yard near you, your not just limited to Supra's. GL.
supra90turbo
shaeff is FTMFW!
MA, 01440
I have an antenna from my car that worked just fine.
I have no use for it anymore, PM me if you would like to take it off my hands.
Doward
4,245
Alachua, FL
rofl... not too worried about it. I've got a 6 disc changer instead of a radio to listen to the tunes :D
So anyone here ever dealt with the lockup solenoid?
Where the hell is the tranny computer? Passanger side kickpanel? (hard to tell from the tsrm :()
Satan
Tampa
I have a replacement mast and nylon cord, but couldn't find alot of detail about replacing them in my existing antenna.
I think I fought with the same issue with my 87T about 8 years ago and ended up just replacing the whole deal w/a universal fit antenna. So, before I go ripping more stuff up, does anyone have the instructions, pics, or links that I can use to get this right the 1st time? TIA!
