Ok, so i get a code 52 after messing with a boost controller and a Rebic LC, clear it, it comes back, removed the Rebic, stock boost set, cleared it and then started the car, it came back within 3 mins, ok, so which knock sensor do i change? How can one t/s to isolate the knock sensors? Do you just change them both? So this is the question? The wiring harness for the engine is just barely a year old, all connectors and wiring is new, and no chaffing. Do you think the ECU is cooked. Just scratching my nogin, how does one bench check a knock sensor? I guess there must be a resistance reading you can use to check to see if it is good or bad.
William 89T
p.s. 16lbs of boost really wakes up the beast. My gosh.
William 89T
