Code 52 help
racerjoe2004
13
California
Aright i know what code 52 is its the knock sensors so i changed those and its still giving the same code. also i checked the wiring and it seems to be good. but now i dont know what to do. can anyone help me
Jspec7m88
1,583
Nappy City
Did you unhook the battery after you did so? Keyword, knock "sensor"...It's part of your computer...sometimes your ECU needs reset.
I don't know of anything else off the top of my head, though.
racerjoe2004
13
California
yeah i did that but still threw the same code could it be faulty ecu
Jspec7m88
1,583
Nappy City
Ehh...It wouldn't be likely...but there's always that slight possibility. :(
When you said you "checked" the wiring...what did this consist of?
If the wires are ran into the object, that doesn't mean it's reading anything...it could just be a bad connection...I don't know. I've never been a Wire Guru...I hate them! :(
jdub
Feb 10, 2006
10,730
Valley of the Sun
Likely the knock sensors need a good ground...search for the "knock sensor rewire". Shaeff makes a kit...PM him.
