code 34??? any help out there? i recently drilled out my stock air flow meter and undid the screw in there(cheap atempt at the lexux upgrade.....). now i have 2 codes that come back up even if i reset my ecu.
here they are:
24 Intake air Temp Sensor Signal not so woried.
34 Turbocharger Pressure NOW IM WORRIED?!?!?!?!?!?!
so heres the question...... what could cause abnormal turbo pressure???
is it the ic pipes(maybe)
or is it in the turbo itself...
i have a 60 trim ct-26 on the way, but its still the only car i got. i might even have the dredded bhg but thats next. just put a new clutch in(yikes!!!). need to save the money for the turbo.
any ideas????? :1zhelp:
here they are:
