code 32
mista_sup
211
atlanta
did any one ever have a code 32 and if so how do you fix it. can't solve the problem:1zhelp: :1zhelp: :1zhelp:
and since i finished my turbo swap when i start the car the oil pressure gauge goes all the way up them slowly comes back down to 0 what could be the cause of that?????
Dunckel
2,949
Spokane, WA
I am assuming since you are now a turbo, you switched your ecu, to a turbo ecu. Code 32 for a turbo is different than that of an NA. Check your HAC sensor. Hell, check to see if it is even plugged in.
