code 32 woes
madseacow
360
Buda, Tx
bad afm right? well I switched out the electronics with a new one from a lex and i'm still having the same problems. what do I fix next?
turbo4toy
208
Los Angeles
I would check all of the wires going to the connector and make sure they are not loose. Did you reset the stored codes by pulling the EFI fuse?
madseacow
360
Buda, Tx
check and check. I even disconnected the AFM hookup from the safc (which for some reason is reading 3hz w/o the engine even running) and it's still no good. could the honeycomb be the culprit? it looks fine tho....
8,895
Well, it is either the wiring or the meter. So, it isn't really check and check.
It could be the ECU, but highly unlikely.
stratoayu
435
surrey
if ur TPS is out, or ur o2 sensor is effed up it can give afm trouble codes. it can happen to u, cuz it happened to me :)
