code 31 boost leak or AFM
slowsupra89
4
delaware
i recently added a large spearco replica intercooler and 2.5 hard pipes, rerouted throught the headlight hole instead of the fender, and car ran like crap for the first few miles then after about 150 miles i now have code 31 can it be boost leaks or can code 31 only mean the afm is bad.
my other mods are 3 inch elbow, dp exhuast and k&n filter, only happened after my intercooler change, i just dont know why its doing it it was running fine, i also have compresoor surge at 4psi and up with the new pipes and stock bov is can there now be too much volume for the stock bov.
black91turbo
Formerly black87turbo
Apr 27, 2006
1,064
Jacksonville, FL
black87turbo;1208105 said:
Your car will run like crap as long as you have a code 31 (unless you go speed density) Try another AFM....
Try running an aftermarket BOV and reroute back into the intake pipe.....although the stock BPV should be able to handle stock boost without problem....
blk92suprat
J Zizzle
Jul 6, 2008
456
USA
process of emilination...
Check afm signal
Check all couplers for leaks
aftermarket bov for added safety/peace of mind
slowsupra89
4
delaware
i dont know anyone else with a mk3 so i have to test the afm and i dont have a multimeter right now. just to make sure though will a boost leak trip a code 31?
slowsupra89
4
delaware
i think the afm is bad, its weired though the cel only comes on when decellereating if im cruising at highway speeds or accelerating the light wont come on and the car drives good but once i let the rpms drop or come to a stop the light is back on, anyone have a afm for sale?
Wills7MGTE
( . )( . )'s RULE!!!!
May 12, 2006
1,077
Jackson, MO
I had same problem a while back, afm was fucked from K&N oil, I have a new AFM now and the K&N isn't as oily now so it should be fine I have had the new AFM for a year no issues. At the same time I had a boost leak which I resolved by replacing couplers with silicon ones on my custom hardpipe setup we did. I also run an HKS SSQV on my auto if you have a stick you'd need to recirculate it, the venting doesn't bother my auto much LOL
grimreaper
2,180
Dallas
how are you pressurizing the crank case (and head) from a boost leak test?. im guessing you left the pcv hose attached to the intake and stuck the tester on.
SupraKingz
65
Winnipeg,Manitoba
I removed the air filter stuck the pressurizing kit on it and pumped it up and it started to leak really bad from the valve cover and two of the I/C piping couplers. And there is a hose attached cirectly to the valve covers from the intake piping so that how it also got pressured.
grimreaper
2,180
Dallas
Take that hose off next time. Your going to push your seals out.
other then that i cant see how a vac leak would cause that code. I would ask the 1J guys.
