I was getting code 12. 25, 26. Code 25 and 26 means running rich and lean. So I replaced the O2 sensor since some wiring on the O2 was messed up( bought a Denso O2), to fix code 25 and 26. Code 25 and 26 came up again, and code 12 usually takes a while to come up(it will eventually come up again). Now that I know its not my O2 sensor for fault code 25 and 26. Can my CPS be causing code 12 25 26? The wring on the CPS is very hard(toasted) and it has alot of oil in the housing.
Also sometimes my car wont start it clicks but the starter will crank the engine alittle till it starts. Pretty sure its the starter contact points.
