code 24, vpc, everything checks out?
di_rosa
never ending project ...
Apr 2, 2005
215
toronto
pulling code 24, new air temp sensor from hks, wiring to and from vpc is good (checked for continuity and resistance), checked resistor in fields harness, and even replaced it for good measure, and i am still pulling code 24 (yes, i have cleared the codes).
i decided to see what voltage the ecu was getting (as per chevyeater), and found that i am perfectly within spec according to the tsrm (i am getting 1.670v and std is 1-3v). i was reving it, going to 5.5k slowly, fast, anything, and the damn thing wouldn't budge.
however, i do not know if this is related, but i bog at around 5k if i go wot, and my readings were not wot (as i was parked).
any suggestions?
