Okay today I hard wired my CPS, removing the connector completely and guess what my car starts now. It stumbles a little when you first start revving and engine light is on at idle but if you rev above 1600rpm engine light goes off. I read the codes and got code 24(familiar to me), and code 31 (24 is intake air temp signal and 31 is AFM signal) I checked the resistance with an ohm meter set at the "2000" reading. Results are as follows:
Ks to E1 1260
E1 to Ks 1095
Vc to E1 1758
E1 to Vc 1678
THA to E2 145
Test were taken in 32 degree F temperature.
Now according to my manual Ks to E1 should be should be 0? I think symbol is to circles together side by side(Does this symbol mean 0?).
E1 to Ks manual said 5k-10k
Vc to E1 10-15k
E1 to Vc 5-10k
THA to E2 @ 32*F 4-7k
So obviously their is a problem. My question is would this be the wiring or the electronic box itself? I tested the connector with the ohm meter. I'm starting to think I should of been testing the terminals on the electronics box itself?
Also a quick question for a noob using an ohm meter. E1 to Ks means positive lead to E1 and ground lead to Ks correct?
Any help/suggestions would be greatly appreciated.
Ks to E1 1260
E1 to Ks 1095
Vc to E1 1758
E1 to Vc 1678
THA to E2 145
Vc to E1 10-15k
E1 to Vc 5-10k
