Code 14
Zrain25
639
Pelham,New Hampshire
The car has always had a little trouble starting when cold. But usually it fires up pretty fast. Today I went out and I had a hell of a time trying to start it. Got it to operating temp and it wouldn't start unless I had my foot on thr gas buried to the floor. It has never done this it's totally random. I got it to school ok and parked it check the code I got code 14.
I know that the ign code but y would it start so randomly. Before I go out and start it I'm gunna check the coil connections and stuff see if there loose
8,898
The random starts are from the bad wiring giving you an intermittent open. Putting your foot on the floor has no effect on its starting. Unless you pour a bunch of gas down the intake. Because when you put your foot on the pedal like that while cranking, stops injection.
Zrain25
639
I give it gas once it stumbling to start. I know that pressing the gas in efi car has no effect during cranking. What wires should I check first the coil pack ground
8,898
14 means the PCM did not get spark confirmation. So injection is halted. 14 could be a break in wiring from the ignitor to the PCM blocking spark confirmation (IGf) or you never got spark, so there was no signal.
Zrain25
639
All the code 14 symptoms iv been reading say there car wouldn't start at all my car started after a little and drove fine. Just had issues starting for some reason I'm leaning towards a bad connection
8,898
Zrain25;1936770 said:
How can I test the ignitor
Pull a plug wire, put in an old plug that isn't fouled, and ground it. If it sparks, you have a break in the IGf wire. I would think more along the lines of a bad pick up signal.
