well i just got everything about squared away and started it up. while trying to set the timing, the car will only idle if the timing is advanced more than 15 degrees. if i try to set the timing to 10 degrees the car will die out.
im getting a code 12.
all the spark plug wires are in the correct order, the CPS is installed the right way.
is there something simple i am missing?
