Code 11
mk3supra
231
Decatur, IL
www.supramania.com
i got rid of the code 52 and its still running bad it bogs down when it goes to spool up, perhaps a boost leak, ill have to look into tha tomorrow. I had a code 52 so i did shaeffs KS re-wire kit and it got rid of the code 52. pulled the efi fuse and fired it up and it showed a code 11. i didnt have this code before. any one have any ideas of wat could have happend? thanks for all the help btw
jdub
Feb 10, 2006
10,730
Valley of the Sun
Code 11 = Momentary interruption in power supply to ECU. It refers to the ign switch circuit, ign switch, main relay circuit, main relay, and the ECU itself.
Pull the EFI fuse again to clear...see if it goes away.
jdub
Feb 10, 2006
10,730
Valley of the Sun
mk3supra said:
pulled the efi fuse and code 11 went away. my battery was dead when i went to start it, had to charge it a bit so maybe that was the cause. thanks for the advise.
Yep - that will do it. Glad it was so simple :)
And you're welcome!
