clutches
cruzinbill
SC3TT
Jun 26, 2005
515
Arkansas
ive been looking at this for a while now and i read both but is it true that you can use a 1jz clutch and flywheel on a 7mgte because i thought the flywheel would be differant
IHI-RHC7
"The Boss"
Oregon
You can use a 1jz clutch disk because 1jzs use the R154. You can maybe use a 1jz pressure plate, although I'm not sure. You can't use a 1jz flywheel, because it bolts to a 1jz crank, which has the same bolt pattern as a 2jz crank.
Hope this helps.
cruzinbill
SC3TT
Jun 26, 2005
515
Arkansas
hmm wich help me realize my next question lol does anyone have a twin plate for the 7mgte i can find them for the 1j but thats all unless i overlooked it
cruzinbill
SC3TT
Jun 26, 2005
515
Arkansas
i had saw that but it is a push type instead of pull type do you know what else would have to be changed in order to use it
CB: I got the Twin complete used with the flywheel insanely cheap through a business contact.
I'm having it modified as I use a Tremec trans and OSG don't do the Ford 10 spline discs but even with all of that I'm still way ahead of the new price.
(I built my Tremec adaptor based on an NA bellhousing so it's a push clutch already)
HPF stock them new but as Figgie said you need to factor in the adaptor kit.
figgie
Twin Cities, Minnesot-ah
tubbie
Yes, powerful Jedi....
Apr 4, 2005
821
Hoschton, GA
A friend of mine bought an OS triple plate set for $200. He needs to order the push type adaptor and that's it...... Still contemplating whether to put it in my car or not.... :evil2:
cruzinbill
SC3TT
Jun 26, 2005
515
Arkansas
well ive also heard that OSGiken offers sprung hub plates that u can get so if its true for ours then ill probly do it i know they offer them for the FC RX-7
figgie
that will only make it an almost on off switch ;)
it still will be harsh engagement. The nature of the material.
Clifton
Scottsdale, Az
figgie said:
well the grass is not always greener on the other side ;)
more specifically this clutch is an on off switch. You can thank the unsprung clutch disc for that.
It being a solid hub or sprung has nothing to do with the quick engaugement. The fact that they don't have a marcel does. Sprung only reduces some shock placed on the driveline on enguagemant. The marcel on a stock disk is what makes the disk so easy to engauge.
