Clutch slips, No Cruise Con, WTF??? I Hate My Car... Arrrgggg
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
:cry: Don't you hate these threads:cry:
Well don't worry it was just a joke to get your asses in here.. :)
Actually both these problems happened:
First: I installed a new clutch last summer, It's been great until a few days ago. If i pumped it up fast, there would be no play in it and it would slip, So I bled the air out a few more times. Bamm Fixed!!!.
Second: Last night I saw that I had no cruise control. So I check the fuses, the vacuum source, the switches(mine were sticky) but functioned.
Now I goto the TSRM and wouldn't you know it, Toyota built in a diag Mode just for the cruise control and wouldn't you know it, It said my clutch was out of adjustment. So I grab a flashlight and sure enough, there was a second switch up there that I did not see before that was telling the ecu that my clutch was in. So I adjust it. Bamm, fixed!!!
I just wanted to say that Toyota rocks...:)
Cliffs: I screwed up my car, but I read the TSRM and I fixed it.. :)
That is all...LOL
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
Yes it is JJ ..Again the wording is my weakness but it was simple really.
KOEO + hold set + push cruise = diag mode
Car running + hold set + push cruise = diag test (with ebrake, brake off and clutch out or in park) and you can test each one, That was way cool...:)
Jeff Lange
Administrator
4,927
20
Sunnyvale, CA
jefflange.ca
There is also the mode with cruise on, then tap set 3 times I believe. I can't remember what they each did, but I used them extensively when adding cruise control to my AE86.
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
Jeff: I think I stumbled on that once while driving but I did not know what I was doing LOL I will have to look again. :)
