I just want to clearify something please, When you bleed the clutch, you are holding the pedal down, Then quickly open and shut the bleeder while the pressure is on., Then release the the pressure off the pedal. Now you have to *MANUALLY* pull the pedal back up. Pump it up a few times and repeat these steps while keeping an eye on the master fluid...
After all this, It still goes to the floor without disengaging the clutch properly and stays there?
