Hello All,
I have a question about my clutch. I am currently doing a total build up of my 87 supra turbo. (engine, trans, etc..) I currently have the engine & transmission in the car with the pressure plate bolted to the fly wheel. The clutch slave cylinder is not hooked up. When i turn the crank the pressure plate and the clutch rotate with the crank but the transmission input shaft does not rotate. The trans is in neutral. So i'm sure i did something wrong or is this normal. I'm sorry if this is a dumb question, i just want to make sure i get this right.
Thanks,
Jim
Thanks,
Jim
