Car Spec: All stock turbo hardtop, except for 5speed swap no manual ecu, and k&n air filter.
Background: When i first installed did the swap this never happened before except for once and it went away and until recently.
Problem: You can hear clicking/rattles coming from the transmission. When i step on the clutch just to give it the minimal amount of pressure it goes away. During driving with windows rolled up and radio off, i can hear it clicking/rattling(sp?). Today, i jacked it up, and took the inspection plates off and noticed that the clutch release bearing hub is loose. Like if i jiggle it, it would probably make the sound i'm trying to describe at 2.5k to 3.0k rpms.
Question: Is the clutch release bearing hub SUPPOSE to be loose, or is it SUPPOSE to be tight with the assembly, including everything from snap rings to wave ring to pressure plate? If it is suppose to be loose, the only way that i can think of is that I will need to adjust the clutch pedal? or is there some other way?
Thanks
Thanks
