clutch pedal stuck to floor and stuck in gear.
chris89
419
Columbia, MO
ok, so i'm pulling into this parking spot in reverse, slowly, ya know...and so i'm pulling in......and i put the clutch in and the car keeps going on......doesn't stop....even with the clutch in so i was like OH FUCK tried the brakes ....didn't help so i just turned the car off. so now It's stuck in the reverse gear and when i push the clutch in it Stays down, i pull it out and press it again....and it stays down.....i cannot pull it out of gear and i can't start the car because it'll just go backward...stuck in reverse.....so WTF do i DO!?!? So i'm thinking it's slave cylinder that i never bled.
chris89
419
Columbia, MO
really? My master cylinder was leaking when i bought so i got it replaced... Brand new one now...i looked at the master cylinder and it's full....Pretty sure it's not leaking..it's brand new...
Squid699
Manic Mechanic
Chesapeake, VA
check your slave clyinder...its probably ass-ploded or has come out of its proper position. That, or you have air in the line/low fluid.
chris89
419
Columbia, MO
hey, but it's on a small hill, it's at like a 10degree angle...i'll have to jack it up onthe slope to bleed it out....or to just see what's up with it....Think I'll be ok? How doi get it out of gear?
