I've had an issue since the day I got this car. The clutch pedal kind of "sticks" towards the end of the return. I included a video below so you can see what I am talking about. I replaced the clutch master and slave with new OEM, and it didn't go away. In the process I also tried to adjust the clutch master rod to give it enough pressure to return, and it stopped the sticking, but the pedal engage/release wound up cartoonishly high from the floor. As in, from having the clutch pedal totally pressed down, the clutch would START to grab at like 80% of the way back to the non-pressed position.
Playing with the adjustment again today, I lined the pedal up at the same height as the brake pedal (they are supposed to be within the same range according to the TSRM) and got the engagement back to a comfortable point closer to the floor. Also had had someone help me bleed the clutch (again). Still no difference. With the clutch master rod disconnected, the spring for the clutch pedal seems to do a pretty good job of flinging the pedal forward and back, but I have no basis for comparison. I've replaced the clutch and flywheel for unrelated reasons during this process. I'm at a loss. Part of me is thinking about just extending the rod for the clutch master. Seems like it would solve the issue.
[video=youtube_share;O9rhFGOxYxw]http://youtu.be/O9rhFGOxYxw[/video]
