clutch master question
MK3Supraman
67
olathe,ks
is there supposed to be fluid on the rod inside the car?
new clutch and it suddenly got kind of mushy and when i let out it chatters like a mother granted its a 6 puck but its smooth one hour the next its chatterin like a son of a bitch
lmk
MK3Supraman
67
olathe,ks
lmk
so idk if the clutch broke in or if the clutch master is leaking
plus fidanza 11lb flywheel
toyotanos
What will we break today?
2,842
Coon Rapids, MN
Fluid should not be leaking past the rear seal on the master, so you should replace the clutch master cylinder, slave cylinder, and flush all the old fluid out. Start with known faults and go from there. Might not fix the chatter, but it's leaking and that's bad.
