Well i just put a cltuch flywheel and pressure plate on the engine and was following these instructions.
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?Section=CL&Page=15
On step two it says to alight the match marks on the clutch cover and flywheel. I didn't see these marks. I'm using an action clutch that driftmotion sells and a 935 motorsports lightened flyhweel. The clutch went over the flwheel nicely and bolted done fine. Can the clutch plate and flywheel be installed incorrectly by not aligning these "match marks"?
