clutch bearing confushion
souprat
fairfax VA
i ordered a TO bearing on monday and i just got back from advanced auto parts. the bearing i got today looks just like one of the bearings that came in my clutch kit(spec stage two). in the kit i have two bearings, one is 1.25in in OD and .5in ID. i also have one with 1.75in ID and 2.75 OD. this last bearing has a ring or a lip that raidiates out from the center that is about 3/8in high. the bearing i just bought(which i think is a TO bearing) looks just like the larger 2.75 OD bearing.
The question: do any of the bearings in a clutch (TO, pilot, release) look alike? should i return the one i got? what does a TO/pilot/release bearing look like? am i insane and have all the bearings i need in my kit and i shouldnt even have had to order any more? pic's would be great if you got em.
L
lanky189
Guest
sounds like you got all the ones you need
the smallest with the smallest .5 inch ID is your pilot bearing.
The larger of the two is your TOB.
souprat
fairfax VA
well thats good to know. i returned the bearing, between that crap and spec being bitches today has been a pain. thanks everyone.
