clutch and fly wheel
mista_sup
211
atlanta
wanted to kno what is a good combonation for a clutch and light weight fly wheel for a 7mgte. i am about to change my rear main seal and figured i change the clutch and fly wheel also. by the way i am still running the w58, have not got a r154 yet.
any sug....
mista_sup
211
atlanta
bump
any sug....
black89t
boost'en down 101
Oct 27, 2007
951
humboldt, ca
stock unless your boosting over 300+ hp. at least 15psi.
letting people know what mods you have would help.
sorry, you have a w58. i have no idea, but i have a good feeling stock will slip.
mista_sup
211
atlanta
did the na to turbo swap. it is basicly still stock. one peace drive shaft, air filter free flow cat and exaust. but, i am asking because my rear oil seal is leaking so i figured i would change all that while i am in there...
forcefedsupra
aka, Turd Furguson
Jul 19, 2005
463
Jacksonville, FL
If this is a daily driver, I don't recommend the RPS flywheel. I have it with a one piece and the driveability went way down. Also, get a full face clutch disc to avoid chatter. I don't know what's available for the W58 but I hope this helps.
mista_sup
211
atlanta
thanks for the input it does help...
Ckanderson
2,644
The beach
ACT makes a full face disk for the w58.
like I have said before I dont recomend lightweight flywheels for the Supra. It makes it harder to launch, and the pressure plate can weld itself to the flywheeel easier.
an act heavy duty street clutch kit would work perfect for you.
