Clunk sound from rear- Anyone ever had a bad half shaft?
supraguy@aol
Well-Known Member
Dec 30, 2005
4,236
Atlanta
I searched for 'clunk', but came up with nothing.
I've been getting a noise from the rear end for a little while now, noticeable when changing from reverse to first, or when shifting. I replaced the diff with another one(also because the pinion seal was leaking), but it didn't change the sound. So i'm wondering if anyone's ever had a bad half shaft-
The driveshaft is basically new, and all mounts to the diff are tight. Any ideas about this- please toss them out here.
Thanks.
metaphysico
Mad Scientist
Jan 2, 2008
428
Gainesville, Georgia
I had a very bad clunk noise in my turbo because the center support bearing was very bad. Besides that in half shaft do you mean one of the axles from diff to wheel or one of the two parts of the drive shaft.
In the case of the axles to wheels I have never seen them go bad on any car that has independent rear suspension but I have seen thousands of front wheel drive ones do that.
As for the drive shaft itself those u-joints can get worn and make a click or clunk sound, click at first then clunk later. If you need I have two rear sections of drive shafts and an extra set of drive axles if you want to swap them out and try.
The u-joints are pretty easy to test if you can get the car high enough. Just hold the shaft still while rotating the other side. Any play here means the u-joints need to be replaced.
For the axle shafts set the parking brake and rotate the axle where it comes out of the diff to see if there is play between the diff and the wheel to check the two joints.
If you need them I have a couple of axles and a few rear halves of the drive shaft. No front parts of the drive shafts for a 5 speed though. Just let me know if you want you can stop by and swap the stuff out and see what happens, or stop by my shop in Norcross and we can get it on a lift and test it out.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,236
Atlanta
My driveshaft is a DSS (driveshaft shop) aluminum unit with HD u-joints.
And no- none of my boots are torn on the halfshafts, and that's why I'm perplexed.
In fact, the halfshafts look almost new, even though they have 326,000+ miles on them.
I guess I'll crawl under the car and try moving things around some more.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,236
Atlanta
So, I jacked up the car and tried to flex everything.
First, I made sure I had no cracks in the subframe. Looks good.
Then I tried moving each halfshaft with the parking brake set. Not a mm of movement on either.
Then I tried the driveshaft. About 1mm, but i had to use a prybar to do it.
I made sure that all subframe and diff mounting bolts are tight as well.
I'm starting to think it might be gear lash in the differential.
Thoughts?
rakkasan
Currahee!!
Fort Campbell, KY
Thoughts?
This is your 2nd differential with the same problem, right? I seriously doubt it has anything to do with the differential.
metaphysico
Mad Scientist
Jan 2, 2008
428
May want to check your rear arms, I remember I had some pretty bad noises from mine before I replaced them, also it was making it so that when I was driving and hit the brake hard at low speed the tire would buckle in. Maybe try that low speed hard braking to see if its suspension instead of drive train.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,236
Atlanta
I tried flexing the subframe from all angles, using a prybar.
The subframe bushings are brand new nylon units purchased from Becauseican.
metaphysico
Mad Scientist
Jan 2, 2008
428
Well if you have time tomorrow (Saturday), bring it up to my shop and we can get it up on a lift and test everything out. The inspection will be free so there is nothing to lose, just a drive to Norcross. Were at the corner of Spalding and Holcomb Bridge if your familiar with the area.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,236
Atlanta
Can't, meta-
Just left town, and won't be back for a week.
Poodles- are those the bushings on the lower suspension arms?
supra90turbo
shaeff is FTMFW!
32
MA, 01440
My Supra has 90k on it and it's doing exactly what supraguy's car is doing. I hope it's not the subframe, and I can't see anything wrong underneath...
Sub'd for answers!
supraguy@aol
Well-Known Member
Dec 30, 2005
4,236
Atlanta
Say Poodles- Do you(or anyone else) know if the Energy suspension kit includes the
#1 and #2 lower arm bushings in question?
Nope, they don't. They're not bushings like what energy makes, they're closer to a ball joint and from what I understand, a royal pain to press out and in.
Gotta get em from the dealer.
te72
Classifieds Moderator
6,608
4
WHYoming
Just had my clutch replaced and now I'm getting the same clunk between shifts or whenever I go from no throttle to any throttle... This has given me lots of things to check out. :)
