clock, radio stays on
roadboy
Supra Owner
Jan 22, 2008
456
Toronto, Ontario
hey, it just started with this problem, everything was working fine. but then a day ago i saw my clock light light up. i can also turn on my radio
my cig light is on as well.
what could cause the clock and other acc on?
checked radio wiring, behind dash,
ign seems ok, still can go to acc and crank, but when i put it to the lock position is dosent turn off the clock ect.
i dont know how to test it. any teach me? :icon_bigg
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?S=BE&P=15
roadboy
Supra Owner
Jan 22, 2008
456
Toronto, Ontario
well i just did the ignition rebuild, everythings fine,
it is the 20a dome fuse in the engine bay (iirc)
i tried pulling the cig, gauge, and radio fuse and they all still work.
my steering wheel dosent lock as well, as in steering lock.
anyone have any suggestions?
roadboy
Supra Owner
Jan 22, 2008
456
Toronto, Ontario
mkiiichip
1,434
WI
To use the diagram you originally posted.
The two connectors shown are the connectors for the ignition switch.
unplug the connector, you will be testing the ignition switch side of the plug (not the body harness side)
With an ohm meter, probe the two terminals shown in the diagram.
For instance, to test the acc mode, put the leads on terminal 3 and 4. you should get a low reading (like you do with the two test leads touching each other). Any reading indicates continuity. So in acc mode you should have continuity between 3&4 but no other terminals.
In "ON" 2,3,4 should have continuity with each other, and 7&8 should have continuity with each other, but the two sets do not have continuity between them, and so on.
roadboy
Supra Owner
Jan 22, 2008
456
Toronto, Ontario
Thanks, will try that 2mr at 7am, and post back results
roadboy
Supra Owner
Jan 22, 2008
456
Toronto, Ontario
so the switch works fine, im also checking fuses
20ADOME- ( is the culprit, making my clock, radio and cig on)
tried pulling gauge-(good, dosent work when i pulled it out)
radio-(i pulled the fuse and it still works)
cig-(pulled the fuse, the cig light still works)
any suggestions?\
i tried taking apart my column, covers, center bezel, couldent find any wires touching or frayed.
unless i change my cylinder barrel (not switch)
