i have a bit of a problem with my starter... car is a 1988 ma70 with a 1jzgte swap. when i turn the key to start it goes 'click' from near the starter. click it a bunch of times, usually 5 or 6 and it will start.
so now im in calgary and its -25 outside, and it justs clicks forever and will not crank. this happened to me on my toyota pickup with a 22r, and all i did was take the starter off and clean the contact up with some sandpaper as it was covered in dirt/corrosion. it worked great after that. i want to try that with this starter, before buying a new one.(can napa even get these starters? anyone have a part number?)
so how can i remove the starter? is it possible if i put it up on jackstands? will it fit out the bottom?
i would go look, but its -25 and snow on the ground right now. yesterday i had to replace my power steering cooler line as it exploded, and in about 5 minutes i froze my hands and ass off. im a d.i.y. kind of guy, i wont trust a shop with either of my toyotas, no matter how freakin cold it is.
thanks for the help
mike
thanks for the help
mike
