I ask this out of curiosity, but if the main & rod bearing clearances are a little looser than what the TSRM calls for, but the oil pump is shimmed, would there still be an increased risk of trouble?
lagged said:why chance it? you could speculate that the increased oil pressure would keep the loose bearings safe, but then again loose is loose, right?
IHI-RHC7 said:Mark, the relief will not open until 40 psi in stock configuration.
The main and rod clearances (along with cam bearing and oil drive shaft clearances) determine oil pressure at idle. With the pump shimmed, you can see upwards of 60 psi at higher rpms, but it does nothing to protect you down low.
The only reasonable thing to do is make sure that the engine is assembled on the tight side of toyota specs.
:biglaugh:IHI-RHC7 said:The only reasonable thing to do is make sure that the engine is assembled on the tight side of toyota specs.
IHI-RHC7 said:The problem is that the pump is a positive displacement pump. At idle, it is full flow and it simply doesn't move enough oil to buil substantial pressure above 10 psi. The only way to cure this is to tighten all the clearances so the engine "consumes" less oil at any given moment, or increase the displacement of the pump, or overdrive the pump.
The only reasonable thing to do is make sure that the engine is assembled on the tight side of toyota specs. If the clearances are loose, and you are stock grind or 10 over, you can get genuine toyota bearings to bring the clearances into spec...
figgie said:keep in mind that as with the turbo
pressure is RESISTNACE to flow (Bernoullis principle at work). Or in scientific terms
as Pressure increases VOLUME MUST DECREASE!! See all electric fuel pumps for proof. You can PLUG all the oil holes and see 100+ psi but you are flowing NOTHING![]()
Electric fuel pumps are not PD pumps, they are vane pumps which opperate at a constant speed and flow a rate that is inverseley proportional to pressure. Our oil pumps DO NOT behave in this fashion.figgie said:Or in scientific terms
