i got clear turn signals and back side markers but does anyone know where i can get clear front side markers? thanks
ILikeCarsYesIDo;1084600 said:thevork, where did you get that IC cover as well as the glass looking shield for the intake?
Custom?
7M-GTEric;1084638 said:And is that possibly an under-hood light switch I see next to the pass. headlight? Looks like the switch that's in my brother's BMW E36 trunk...hmm
Jay, what did you do to modify your fronts to fit? I ordered a set of rears to use on my fronts.suprahero;1084270 said:I modified the front of mine to make them work as well.
CRE;1090790 said:??? Err, guyana, I believe they meant moving the FRONT markers to the trim behind the front wheel well instead of in front of it...
And, yes, it's been done. IIRC, the blue JDM MKIII which shows up so often in lambo door and vented hood discussions has that done.... I think that was the one.
Kristian_Wraae;1084688 said:These will fit without modification and are also diamond cut as the front blinkers.
http://www.venturi-racing.de/shop/t...arglas-blinker-set-seiten-front-komplett.html
