Well a week and a half ago i did a boost leak test. We heard a POP noise during which and heard air leaking towards the front of the engine. We couldn't figure out what it was. People suggested it was the ISC valve but it didn't sound like it was coming from there.
Well i've noticed my oil levels drastically dropping. I went through almost 4 quarts of oil in a few days and about 50 miles tops. I went to the beer dristributor and noticed the drips. :cry: :cry: . Its leaking rather steadily out the front of the engine. Looks to be directly below the crank pulley, so i figure its the oil pan gasket or front main seal??
Either way, my engine has 4500miles on it! should this have happened during a boost leak test?! i used 15lbs during the test. The pop occured when i plugged up the PCV system house from the TB so i makes sense pressure was in the crankcase which caused the blow.
So now im donw a car during the most busy travel times of the year and lots of family to see.
Whats worst case scenario for a fix for this. Is main seal or oil pan gasket a good assumption? if so, how hard are these to fix. Must i remove engine to remove oil pan and replace gasket if its that? :1zhelp: how difficult is the front main seal to deal with?
