choosing the right hg
Hobbes992
65
Tampa, Florida
alright, I have a NA 89, 5 speed. the head gasket has to be replaced but I want to put something with quality in it so that this can be avoided again for a long time. What is pretty much the best of the best when it comes to headgaskets. Yes, I understand I'm not running any boost but I don't care I want to spend the extra money on the hg and studs.
Hobbes992
65
Tampa, Florida
Well that's not even an issue. I'm going to spend a looong time on this so everything is going to be done right. I'm going to be taking a picture every time I take a part off AND label everything just so it goes smoothly. I am more interested in getting a metal hg though really. I was just wondering about brands.
daledoe
KILL U
Nov 18, 2005
1,467
MAINE
I'm going to do it the right way. Its a JDM motor but I'm still going to have the head and block resurfaced.
7MA61
7MA61
Aug 27, 2006
98
Sydney
HKS 1.2mm MHG one in mine done close to 50,000kms now and lasted 3 years, car cops a thorough caning. As per MCD motorsports to use a Metal head gasket the block and head have to have a mirror like perfectly flat surface.
Tire Shredder
569
Oshawa
although I may get a lot of flak for this...I think in some cases a metal headgasket is overkill...at least for an NA.
I know a local toronto club member that has a spotless 89. His engine has a stock toyota headgasket which he has torqued down to the proper level (much higher than stock - I can't recall the number though) and is running 12psi on his CT-26. He's had this setup for many years and has not had any trouble.
I think for an NA, a toyota gasket may be just fine when torqued properly...
bluedragon17
87 NA-T baby!!!
Sep 14, 2006
382
Vacaville, CA
this is true i have a mhg and arp head bolts on my NA and i have no problems with it the composite one that was in there before got overheated once before i changed out the whole cooling system and from there it was on the road to a bhg. Mhg is a good way to go because it gives you that little extra breathing room knowing that you wont blow one up. If only i could say the same about rod knock..............
s383mmber1
3,614
Somers New York
ANY headgasket can blow easily.
ITS ALL IN THE TUNE.
Get your car tuned with a stock headgasket = no problems
Run lean on a exspensive MHG = blown.
Theres other factors than just the material its made out of.
shaeff
Kurt is FTMFW x2!!!!
11
Around
i don't care if you got a motor that was just bought from the toyota factory- you'd still need to get it lapped... (head and block)
-shaeff
s383mmber1
3,614
Somers New York
-shaeff
Correct, just cause its JDM and only "45k miles!"
Doesn't mean its perfect, or has 45k miles;)
