8
88boostr
Guest
hey i read somewhere that you can check for a vaccume leak by looking at your boost gauge at idle(mine is -20psi) and take off one of the vac lines and see if it changes, if it does change that means you dont have a vaccume leak, but if it doesnt change you have a vac leak, this seems like it would be a good way of testing but i am just making sure.the reason im asking is becuase im having boost problems.thanks
