Check engine?
mtoxracerfss
Boost Addict
Oct 8, 2005
177
Toledo
Just wondering how i can check the engine code myself? I went to an import tuning shop to get a code read, and they said with the obd1 system like we all have, youd have to have a different connector for each individual car. He said that i could do something to make the check engine light flash and tell me the code? Is this true? If so how do you do it?
I have a check engine light that came on when i was going to work, and when i boosted it felt almost like fuel cut but not as violent. Only happened when the turbo got mid spool. When i got off work.....no engine light....engine ran strong as hell, and boosted perfectly, which leads me to believe there is a sensor going bad, and id like to find out which one and replace it.
