Check engine lights SUCK!!!!
TheNewRed
572
WA
Ok today i replaced my factory boost gauge with an autometer (just bored out a hole for fitment). now the damn computer is throwing a 32 code(Mass Air sensor) and a 52 code(Knock sensor), is it beacause i disconneted the factory setup or what. Someone out there has had to have done this before any help is appreciated guys, thanks.
2543arvin
Moving to Japan!!!
Nov 30, 2006
879
Jacksonville, NC
I know the code 52 bug, I replaced my turbo and head gasket and then when I put it back together, I got the knock sensor code. It was random, yet still a problem. So I ordered the knock sensor rewire kit from Shaeff(mod on here) and installed it and no more code 52!
As far as the AFM code, I didnt get 32, I got 31 and it was random as well, so I replaced it for the Lex AFM with new electronics, no more code 31. I will have to double check that code 32, because that doesnt sound like the AFM code.
2543arvin
Moving to Japan!!!
Nov 30, 2006
879
Jacksonville, NC
Yep, for the n/a supra it the AFM code, but for your 87 7MGTE it the HAC sensor code. I pulled this from cygnus.
HAC Sensor Signal(7M-GTE)
Diagnosis(HAC Sensor Signal(7M-GTE))
* Open circuit or short circuit in HAC sensor signal.
Trouble Area
* ECU
I believe that the HAC sensor on the 87-88 models is located on the ECU, so double check that and start there.
TheNewRed
572
WA
So shaeff i have been hearing about this knock sesor rewire kit what does this kit consist of and can i do it myself????:evildeal:
