Check Engine Light Codes 12 and 71...how to fix??
SupraFreak619
45
Hemet, CA
Hi guys ive had my check engine light on for awhile now it goes on and off, finally decided to find out what the codes were and 12 i believe is RPM Signal/Distributer or Circuit, ECM. and Code 71 EGR System Malfunctioning/EGR Temp. Sensor or Circuit, EGR-VSV, ECM?? HELP PLZZ! Can me procrasinatiing on these codes damage my engine? o_O How can i fix them? Thanks!~
SupraFreak619
45
Hemet, CA
Got it thanks! ill make sure to do that as well, nice write-up btw very straight forward. Now if for some reason after i do all this the codes still keep coming up what coudl be the next step? I just did a BHG job recently about 800 miles ago, could this have to do anything with the codes??
benchwarmer
Straight Cougar
Aug 2, 2007
510
Lancaster, CA
Not likely. Usually when an error code pops up AFTER you fix a problem it turns out to be a wiring issue. Check out those grounds and go from there.
SupraFreak619
45
Hemet, CA
Hey thanks alot that cleaning helped!
