check code help.
AZN MK3
341
Now in the U.S.
ok, here's my problem. I went to the site i searched on SM (http://www.cygnusx1.net/Supra/TechTips/engine_error_codes.aspx) and when it says to connect TE1 and E1 together using a paper clip or some sort of way of making the contacts touch. I actually don't see TE1. all i see is just plain T. Is that where im suppose to connect it to or am i just loosing my mind. (I have a 87 N/A 5spd that i just bought) and can't figure out where TE1 is at. I looked at the diagram and followed the picture where TE1 is located and still nothing the CEL doesnt even blink at all so am i doing anything wrong? Helpp Please.... Thanks
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Can you see it now? Pay no attention to the circles, they are for something else. Check the labeling on the right.
AZN MK3
341
Now in the U.S.
yea I looked at the diagram on the box but it says T instead of TE1. so that's where I got confused. I was like where is TE1 and when i compared diagrams I was wondering if T=TE1 or not...
AZN MK3
341
Now in the U.S.
CRE;1442304 said:
TE1 = T in the '88 TSRM and I believe my diag box just says T or T1
Thanks... I'll check it tomorrow in the day time since its already dark here... so I hope I can get some codes to see why it won't start.
AZN MK3
341
Now in the U.S.
Ok... finally after working on the car for a while i got the error code 14. i changed the distributor sparks now...On the side note, come to find out, im not getting power to my fuel pump at all... im confused now... i checked the relay its fine. i checked the open circuit relay its fine... still nothing... and obviously the efi relay works cuz if it didn't i wouldnt get codes right? so what could be going wrong?
